Applications Systems
Change the default VIM connection port for polling
This article describes how to change VIM polling from the default port 443 to a non default port.
10/16/2018 6:21 PM
5/9/2019 1:40 PM
This article details how to change the VIM polling from the default port 443 to a non default port.
Server Application Monitor
Run the following query against the database:
insert into dbo.VIM_ServiceURIs(ServiceURI) values ('https://{0}:444/sdk')
Two records in the table that look like the following appear:
https://{0}/sdk
https://{0}:444/sdk
You may now be able to collect data on both 443 and 444 ports against Vcenters.
