Change nodes polling engine ID in the SolarWinds Platform using the database manager.
This article describes how you can assign nodes to the correct Polling engine or moving nodes from one Polling Engine to another using the database manager.
10/16/2018 9:34 AM
6/30/2025 2:41 PM
This article describes how to change the nodes' polling engine ID when you are prompted with the following warning message during the Configuration Wizard and/or a migration is performed.
Multiple polling engines detected. The database you have selected is currently being used by another SolarWinds application at (Orion Server Name) Do you still want to use the selected database?
Network Performance Monitor
Please note the following for all SQL queries below:
In SolarWinds Platform 2022.3 and newer, the EngineID column is a key and can't be edited directly; the NodesData table will need to be updated to match the EngineID instead.
  1. Stop all Orion services using the Orion Service Manager.
  2. Go to All Programs > SolarWinds Orion > Database Manager
  3. Run the following query:
    SELECT TOP 1000 * FROM [dbo].[Engines]
    1. Pull the EngineID and run the final query adding the correct EngineID to update all nodes.
    2. Run this query:
      Update [dbo].[Engines] set EngineId = 'NumberGoesHere'
      Where EngineId =  'NumberGoesHere'
      • To update the NodesData table in SolarWinds Platform 2022.3 and newer:
      Update NodesData Set EngineID = (the new polling engine ID you want to move the nodes to)
      Where EngineID = (the old polling engine ID)
      Sample: --Update NodesData Set EngineID = 4 Where EngineID = 2
      1. Start all services using Orion Service Manager.(All Programs > Solarwinds Orion > Orion Service Manager)
