Applications Systems
Change fetching method for Window Application Monitors
Steps for changing fetching method on Window monitors.
How to change the fetching method for Window Application Monitors from WMI to RPC.
- Go to the Application monitor detail page.
- Edit application monitor.
- Expand the component monitors.
- Change fetching method from WMI to RPC.
- Save the template.
These steps can be used to change back to WMI as well.
