Change column values on the Node Tabular Universal Device Poller
This article shows how to change default column labels shown on the Node Tabular Universal Device Poller.
10/22/2018 7:44 PM
3/10/2022 6:13 PM
This article explains how to change the column label IFSPEED shown by default on the Node Tabular Universal Device Poller (UnDP). Network Performance Monitor (NPM).
The following example displays how to change the IFSPEED column label.
The column name is a default name coming from your UnDP as shown in the following:
Note: If you want to change the title you need to edit the widget and you can change the display title and this will not change the MIB original name.
Example:
  1. Go to the Orion server and open UnDP.
  2. Right-click ifSpeed and select Label.
  3. Change the name.
  4. Click Finish.
  5. Go back to the Web Console and refresh the screen.
 The new column name is now displayed on the table.
