Centralized upgrade does not prompt for upgrade of Scalability Engines post upgrade of Primary Main poller to 2022.4.1
Centralized upgrade does not prompt for upgrade of Scalability Engines post upgrade of Primary Main poller to 2022.4.1, instead it prompts to upgrade to 2023.1
1/23/2023 4:34 PM
5/13/2023 12:38 AM
You upgraded Solarwinds from 2020.2.1 and higher to 2022.4.1 using offline installer and completed configuration wizard.
Now you would like to upgrade the remaining Pollers to same version i.e 2022.4.1 via My deployment > Updates page
However, there is no option to upgrade the pollers, instead we get these options only.
Orion Platform
Known issue/Bug in product
Upgrade each poller manually using the offline installer (Using same offline installer as version of Primary polling engine)
Issue will be Resolved in SolarWinds Platform 2023.3.
