Security Compliance
SolarWinds Update Catalog was successfully downloaded, the catalog could not be read
Third party update sync fails with error (SolarWinds Update Catalog) was successfully downloaded, the catalog could not be read.
11/1/2022 10:00 AM
2/5/2023 3:06 AM
Some customers reported their third party catalog update sync fails with following error
Solarwinds Update Catalog sync fails
Errormessage:
Although the catalog (SolarWinds Update Catalog) was successfully downloaded, the catalog could not be read. Reason: The file exists. Stack Trace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.Path.InternalGetTempFileName(Boolean checkHost) at Microsoft.UpdateServices.Administration.Internal.UpdateServicesPackage.Verify()
Error on web console
Patch Manager
Unknown
1. Clear C:\Windows\Temp folder or %AppData%\Local\Temp\ewtmp-*
2. Try to run the Synchronize again or Importing the Catalog
If that does not help, you may have to follow the steps in Catalogs synchronize successfully but new packages are not added
