Cannot connect to the SolarWinds Orion database when configuring an Additional Polling Engine
If the Configuration Wizard cannot access the SolarWinds Orion database when configuring an Additional Polling Engine, enable TCP/IP and named pipes in the SQL Studio to connect to the database.
In the SQL Management Studio, enable TCP/IP and named pipes access.
See Enable Named Pipes and TCP/IP Connections (© 2016 Blackbaud, available at https://www.blackbaud.com/files/supp...onnections.htm, obtained on December 3, 2018.
