Applications Systems
Cannot authenticate to remote DPA instances from a Central DPA using AD/LDAP
You cannot authenticate to a remote DPA instance from the DPA Central Server. This can happen in the following cases: 1) The DPA Central Server cannot connect to your AD/LDAP domain server. 2) The credentials supplied are invalid.
- The DPA Central Server cannot connect to your AD/LDAP domain server.
- The credentials supplied are invalid.
This is a side effect of one of our anti-lockout features for AD/LDAP. Many AD/LDAP servers are configured to lock out user accounts for failed passwords. To avoid locking accounts, we don't try to log on to any remote instances using AD/LDAP if you don't log on to the Central DPA with a valid AD/LDAP credential first.
- Log on to the Central DPA using valid AD/LDAP credentials.
-or- - Log on to each remote DPA instance separately without using the Central DPA.
-or- - If your AD/LDAP server does not lock out user accounts for failed password failures, you can configure your Central DPA instance to always attempt authentication with remote DPA servers:
- Edit the file <dpa>\iwc\tomcat\ignite_config\idc\system.properties
- Add the following line:
com.confio.iwc.client.factory.ldap.login.on.fail=true - Save the file and then restart the Central DPA.
