Applications Systems
Can SAM monitor Apache Spark?
Can SAM monitor Apache Spark? Server & Application Monitor. Native support for Apache Spark Monitoring. SNMP CPU Memory Volumes Metrics Log Parsing JMX Custom Scripting
10/16/2018 5:51 PM
6/25/2020 9:38 PM
This article answers the question if SAM can monitor Apache Spark.
Server Application Monitor
There is no native support for Apache Spark Monitoring through SAM.
The Node itself can be monitored via SNMP. With this, you should be able to monitor the basics of the Node such as CPU, Memory, Volumes, and others.
Furthermore, you can monitor processes using SAM. You can get this information via SNMP.
To get other metrics, you can use a combination of:
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
