Call Quality metrics showing as Unsupported
Call Quality metrics showing as Unsupported.
- Incorrect Call Manager settings
This is due to the CM settings, if the Call Diagnostics Enabled CUCM parameter is not set, or is only for some types of calls.
Even if this is set, some calls will not have quality information.
- Only calls terminated by an IP phone or MGCP gateway on both ends will provide call quality metrics.
Any zero length calls (failed, busy, among others) will not have any call quality metrics information.
