Applications Systems
Calculate SQL Disk Write and Read latency
This article explains how SQL Disk Write and SQL Disk Read Latency is calculated in DPA as well as where it is saved.
Polling Queries
I/O stats polling is done every 20 seconds (default value, IO_STATS_POLL_INTERVAL) and is stored in memory.
SQL Server Poll Query
SQL Server Statistics SQL
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. SELECT a.database_id, a.file_id, b.name as fname, db_name(a.database_id) AS dbname, a.num_of_reads, a.num_of_writes, a.io_stall_read_ms as read_latency, a.io_stall_write_ms as write_latency, a.num_of_bytes_read, a.num_of_bytes_written, UPPER(SUBSTRING(b.physical_name, 1, 2)) AS disk_location FROM sys.dm_io_virtual_file_stats (NULL, NULL) a JOIN sys.master_files b ON a.file_id = b.file_id AND a.database_id = b.database_id ORDER BY a.database_id
- Read Latency: (Change in io_stall_read_ms / Change in num_of_reads)
- Write Latency: write_latency
- Read Throughput: (Change in num of reads) * (avg block size (for reads) * 1024)
- Write Throughput: (Change in num_of_writes) * (avg block size (for writes) * 1024)
Oracle Poll Query
Oracle Statistics SQL
-- Scripts are not supported under any SolarWinds support program or service. -- Scripts are provided AS IS without warranty of any kind. SolarWinds further -- disclaims all warranties including, without limitation, any implied warranties -- of merchantability or of fitness for a particular purpose. The risk arising -- out of the use or performance of the scripts and documentation stays with you. -- In no event shall SolarWinds or anyone else involved in the creation, -- production, or delivery of the scripts be liable for any damages whatsoever -- (including, without limitation, damages for loss of business profits, business -- interruption, loss of business information, or other pecuniary loss) arising -- out of the use of or inability to use the scripts or documentation. -- These are data files SELECT kcfiofno AS file_id, kcfiopyr as num_of_reads, kcfiopyw as num_of_writes, kcfiopbr as num_of_blocks_read, kcfiopbw as num_of_blocks_written, kcfioprt as readtime, kcfiopwt as writetime FROM x$kcfio WHERE kcfiofno <= ? UNION ALL -- These are temp files SELECT kcftiofno + [maxDataFiles] AS file_id, kcftiopyr as num_of_reads, kcftiopyw as num_of_writes, kcftiopbr as num_of_blocks_read, kcftiopbw as num_of_blocks_written, kcftioprt as readtime, kcftiopwt as writetime FROM x$kcftio WHERE kcftiofno <= ?;
- Read Latency: (Change in READTIM) / (Change in PHYRDS)
- Write Latency: (Change in WRITETIM) / (Change in PHYWRTS)
- Read Throughput: (Change in PHYBLKRD * (blocksize/1024))
- Write Throughput: (Change in PHYBLKWRT * (blocksize/1024))
Notes: readtime and writetime conversions to milliseconds done by DPA:
- Oracle 11.2 and above will multiply by .001 (divide by 1000)
- Oracle 11.2 and lower will multiply by 10
