CXPACKET SQL WAIT Stats
This content will describe SQL Server wait type that can be encountered more or less commonly, which includes the description, steps that should be taken, and additional resources that could be used for troubleshooting.
10/8/2021 12:39 PM
10/8/2021 12:39 PM
Indicates that SQL is waiting on a Parallel process to complete. This can be a sign of resource issues on the SQL server (CPU, MEM, DiskIO) or the query itself is poorly written.
Network Performance Monitor
Description
A lot of the long-running queries are being parallelized. This is not necessarily a bad thing but it does consume additional CPU resources. If processor utilization is very high (typically above 80%) this wait should be investigated
Suggested solutions
  1. Examine high CPU queries to see if they can be optimized.
  2. Investigate changing default MAXDOP and parallelism settings (links below)
  3. Indexing, look for high CPU parallel queries
The content posted herein are provided as a suggestion or recommendation to you for your internal use. The information set forth herein may come from third party website or customers. SolarWinds is not liable for any downtime or any issue that may occur if you perform the following suggestions on the link provided. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.
