CPU load alert did not trigger
This article discusses an issue where the CPU load alerts that the customer setup did not trigger even though the Orion node summary shows that a CPU went above the threshold configured on the alert.
4/7/2020 9:29 PM
2/11/2025 11:47 PM
This article discusses how to create a custom SQL alert to monitor the load on individual CPU cores.
Network Performance Monitor
The alert is monitoring the average CPU load of a node. In this case, the node has 4 CPU cores. 1 CPU showed 100% utilization. However, the alert did not trigger because the average CPU utilization of the node is below the configured threshold to trigger the alert.
The alert in the following example checks the average CPU load of each node. This is the reason why it did not trigger on 1 of the nodes that show high CPU utilization on 1 of the 4 CPUs. The average CPU load of this node by the time a simulation was performed was 12%. The time period when the SolarWinds Platform should have triggered the alert as expected only shows 36.25% CPU average utilization(CPU 1=100% + CPU 2=3% + CPU 3=12% + CPU 4=30% / 4 is equal to 36.25%).
There is no native alert that monitors the CPU load of each of the CPU cores of a node. However, you may create an alert and use a custom SQL query that checks for the utilization of each of the CPU of a node (choose I want to alert on Custom SQL Alert).
Use the basic SQL query below as an example: This looks for a node that has 'test' or 'test2' custom properties and has a CPU load of more than 1 percent of CPU utilization. Work with your database admin to fully customize the SQL query as we do not support customization of the SQL queries. We can only provide you with the tables needed to fetch the information.
select nodes.NodeID, nodes.Caption, CPUMultiLoad.TimeStampUTC, CPUMultiLoad.AvgLoad
from Nodes
join CPUMultiLoad on Nodes.NodeID = CPUMultiLoad.NodeID
join NodesCustomProperties on Nodes.NodeID = NodesCustomProperties.NodeID
where
NodesCustomProperties.City ='test'
OR
NodesCustomProperties.City ='test3'
AND
DATEDIFF(mi, CPUMultiLoad.TimeStampUTC, SYSUTCDATETIME()) < 5
and CPUMultiLoad.AvgLoad > 1
If this query resulted in at least 1 row. The alert should trigger.
