Applications Systems
Business Layer plugin fails to load in DPA Integration Module
What to do if you see the "BL Plugin Failed To Start" event type in the Events view in the Orion Web Console.
10/29/2018 9:21 PM
3/6/2020 9:00 AM
In the Events view in the Orion Web Console, you see one or more of the following events:
  • Event Type: BL Plugin Failed To Start
  • Message: Plugin “DPA Business Layer” failed to start on [YourOrionServer]. Please restart the Module Engine service on [YourOrionServer].
Database Performance Analyzer
The SolarWinds Information Service V3 is not running when the DPA Integration Module Business Layer Plugin starts inside the SolarWinds Orion Module Engine service.
This may also occur when the SolarWinds Information Service V3 crashes while the DPA Integration Module Business Layer Plugin starts.
Make sure the SolarWinds Information Service V3 starts before the SolarWinds Orion Module Engine. You can manage these services with the Orion Service Manager application installed on the Orion server.
If you are not using the DPA Integration Module and you have not integrated the Orion Web Console with a DPA server, there is no need to do anything. You can ignore these false errors in the Events view.
