Tools
Bulk Action (Add/Delete) for Parts in WHD
This article describes how to add/delete multiple PARTS in WebHelpDesk.
- Use the export the Parts to TSV or Excel and Download the Parts template
- Copy and paste the contents to the template and set the Delete column to Y and then import it via the data import feature
- This will set the parts marked as deleted in the database.
- In the database, the table is called "part".
- Import the new list of Parts.
