Tools
Block remote keyboard and mouse in DRE
This article details how to keep a remote input from interfering during a session, and how to block a remote keyboard or mouse input.
4/9/2019 8:14 PM
4/9/2019 8:14 PM
This article addresses the following:
  • How to keep the remote input from interfering during a session?
  • How to block the remote keyboard/mouse input?
Dameware Remote Everywhere
You can disable remote input during a session as follows:
  1. Select the Remote Desktop tab.
  2. Select the drop-down menu to the right of Remote Desktop (looks like a downward facing arrow).
  3. Select the Commands sub-menu.
  4. Enable Block Remote Keyboard and Mouse (or use the hotkey combination Shift+Ctrl+B).
