Security Compliance
BitLocker and SEM
With BitLocker installed, SEM visibility of audits events is reduced.
8/28/2019 4:12 PM
6/4/2020 8:40 AM
With BitLocker installed, SEM visibility of audits events is reduced. This is expected behavior of Bitlocker.
Security Event Manager
Bitlocker is an encryption program and so by its very nature reduces the audit events SEM can report on.
There is no workaround and this is expected behavior.
When BitLocker is acting on USB drives, SEM only reports USB connects and disconnects.
When BitLocker is not acting on USB drives, the usual USB SEM audit functions are available to see, read/write, executable attempts on the device, etc.
Learn more about BitLocker here (© 2020 IDG Communications, Inc, available at https://www.pcworld.com/, obtained on January 6, 2020).
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
