Best practices for upgrading Orion
This article describes the best practices that would help avoid missteps and ensure minimal downtime when upgrading your Orion environment.
- Take a full backup of your Orion database. The Orion database holds all your production information except for reports created using Report Writer.
- Note: If you have an automated backup solution in place, verify that there is a current backup before completing an upgrade.
- Proceed on backing up the Reports folder. It holds all of the canned and customized Report Writer reports.
- By default, the Reports folder on a 32 bit OS can be found in C:\Program Files\Solarwinds\Orion.
- By default, the Reports folder on a 64 bit OS can be found in C:\Program Files x86\Solarwinds\Orion.
- Note: If you installed the Orion applications on a different drive, you need to back up the Reports folder from that installation directory.
- Stop all Orion Services using the Orion Service Manager. Be sure to do so on the primary Orion server, all additional Web servers, and all additional polling engines.
- Note: If you stop services using the Windows Control Panel, stop all SolarWinds services except the SolarWinds Administration Service.
- Run the installer for the product you wish to upgrade: first on the primary Orion server, then on any Additional Web servers, and last on any Additional Polling Engines.
- Notes:
- You can use the Orion Installer to generate the correct upgrade path if you are upgrading from an older installation
- The Configuration Wizard must be run after each installation. Please do not skip this step after an upgrade to avoid unnecessary downtime.
- Notes:
- Verify that Orion is working as expected once the upgrades are complete.
