Backup device configuration through Avocent console using a different port
This article tackles if it is possible to use Avocent console to connect to the router/switch on a certain port in order to backup the configuration of the device.
SolarWinds does not support using third party console to connect to a device using another port to proceed with the device configuration backup.
The backup of device configuration must be done by connecting directly to the device without any third party console.
