Tools
Back up Juniper network devices to restore a running configuration
This article describes an alternate command to back up Juniper network devices. The typical command used (show configuration) outputs the config in a format similar to a script, which cannot be copied and pasted to restore a running configuration.
10/8/2018 10:41 PM
11/23/2021 2:38 AM
This article describes an alternate command to back up Juniper network devices. The typical command used (show configuration) outputs the configuration in a format similar to a script, which cannot be copied and pasted to restore a running configuration.
Kiwi CatTools
n/a
  1. Within the activity Dvice.backup.running config, go to Edit > Options tab.
  2. Select Use Alternate command.
  3. Paste the following command:
    show | display set | no-more
