BACKUPBUFFER SQL WAIT Stats
This content will describe SQL Server wait type that can be encountered more or less commonly, which includes the description, steps that should be taken, and additional resources that could be used for troubleshooting.
10/8/2021 1:47 PM
10/8/2021 1:47 PM
This wait stats will occur when you are taking the backup on the tape or any other extremely slow backup system.
Network Performance Monitor
Description
A backup operation is waiting for data or a buffer for data (to write for backups and to read for restores). Note that all backup waits are accumulated for restore operations too
Suggested solutions
  1. Investigate whether backups are going to a slow device, upgrade device if possible
  2. Use backup compression if available
The content posted herein are provided as a suggestion or recommendation to you for your internal use. The information set forth herein may come from third party website or customers. SolarWinds is not liable for any downtime or any issue that may occur if you perform the following suggestions on the link provided. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.
