SolarWinds Avior
Avior Error: Cloudflare block symptom when submitting SWQL from the Home chat shortcut
A Cloudflare block page may appear when submitting a prompt containing SWQL from the Avior Home or header chat shortcut. The issue is caused by the shortcut sending the prompt in the URL, which could cause Cloudflare to flag SQL-like text. A product fix was deployed to all environments on October 29, 2026. Users can resubmit the prompt from the Home or the header shortcut.
10/29/2026 4:14 PM
10/29/2026 7:34 PM
When a user submits a prompt containing a SWQL query through the Home or header chat shortcut, the prompt could be included in the browser URL. Cloudflare could block the request and display a page such as:
Sorry, you have been blocked. You are unable to access [Avior host].
The same prompt could work when submitted from Chat in the left navigation. This difference was specific to how the shortcut started a chat session; it did not mean that the SWQL query was invalid.
SolarWinds Avior
The Home and header shortcuts initially sent the chat prompt as a URL query parameter. Cloudflare's security filtering could interpret SQL-like SWQL text in that URL as suspicious and block the request. The prompt transport in the shortcut flow—not the SWQL syntax—caused the issue.
A product fix was deployed to all environments on October 29, 2026. The Home and header shortcuts now create the chat session through a POST request instead of placing the prompt in the URL. Submit the prompt again from the Home or header shortcut.
If the block page still appears after the fix:
  • Record the approximate time and the Cloudflare Ray ID shown on the block page.
  • Note which shortcut was used and the Avior environment.
  • Contact Support and include the details above. Do not include sensitive prompt content in an unredacted URL or screenshot.
