Availability of serial numbers using a Universal Device Poller in NPM
You may encounter a situation where the serial numbers of devices that are no longer available on the network are needed.
10/12/2018 12:47 PM
12/9/2019 12:34 PM
Network Performance Monitor
As serial numbers can only be polled via a Universal Device Poller due to lack of a consistent serial number OID across devices from different vendors, there is no table in NodesData which corresponds to serial number.  Therefore, if the devices were not polled via Universal Device Poller at the time they were on the network, this information will not be available.
