Database Management
Auto-generate an Azure SQL mass registration file for DPA
This article provides a PowerShell script plus instructions to auto-generate a CSV file containing the Azure SQL databases to monitor with DPA. You can upload this file to DPA to mass register all the database instances together.
Each registered database creates load on DPA and its repository. If you are using an Azure SQL database as your repository, you could overwhelm the database if you register too many databases at once. Please see the Administrator Guide on recommended DTU levels.
- Download one of the following scripts:
- For DPA 2021.3 and earlier, download this script.
- For DPA 2022.1 and later, download this script.
- Download and install Azure PowerShell (© 2017 Microsoft, available at http://www.microsoft.com, obtained on January 9, 2017) from Microsoft.
- Open the PowerShell console.
- Set the policy level based on your company policy requirements.
Set-ExecutionPolicy UnrestrictedThe available levels are Unrestricted, RemoteSigned, AllSigned, and Restricted. See this Microsoft article (© 2017 Microsoft, available at http://www.microsoft.com, obtained on January 9, 2017) for more information.
- Log in using your account.
Login-AzAccount - Select your subscription.
Get-AzSubscription -SubscriptionName YOUR_SUBSCRIPTION_NAME | Select-AzSubscription - Run the PowerShell script you downloaded.
- In DPA 2021.3 and earlier:
.\GenerateMassRegFile.ps1 - In DPA 2022.1 and later:
.\GenerateMassRegFile_2022-1_and_later.ps1
A file named
massreg_sql_database.csvis generated. - In DPA 2021.3 and earlier:
- Edit and save the CSV file. Enter the required information in each column. Do not delete the header row.
SolarWinds recommends that you register less than 50 databases at a time. Trim the CSV file accordingly.
- In DPA, click Options > Mass Registration.
- Click Choose File, and locate the file.
- Click Load Registration File.
