Auto Launching NOC View
How to automatically launch a NOC view in NPM.
Automatically have a local NPM user launch NPM in NOC view mode, passing the users credentials in the URL.
Create A NOC View
- Enable Left Navigation to activate rotation of multiple pages (presentation mode)
- Add as many Tabs as needed
- Enable NOC view mode
- Set rotation time
- Done and Go to NOC
Once you have created your NOC view and is satisfied on how it looks like, it is now time to create the bypass for the login.
Creating bypass for the login
1. Go to Settings
2. Click on "All Settings"
3. Click on "Web Console Settings"
4. On WINDOWS ACCOUNT LOGIN Select “Enable Automatic Login” on the drop down menu
5. Click on Submit.
