Tools
Authentication failed: Error_Remote Message: System Error: -2146893048 when using Dameware MRC
Authentication failed. System error -2146893048. The token supplied to the function shows as invalid when logging in via MRC Windows NT challenge/response.
10/7/2018 8:54 PM
3/13/2025 8:26 PM
This article provides brief information on the following error:
System Error: -2146893048 is an Authentication failure error returned from the remote machines operating system.
The error is usually displayed when Mini Remote Control is configured to use Windows NT challenge/response as an authentication method.
Kerberos is used as a preferred authentication method. In general, joining a client to a Windows domain means enabling Kerberos as the default protocol for authentication from that client to services in the Windows domain and all domains with trust relationships to that domain. In contrast, when either client or server or both are not joined to a domain (or are not part of the same trusted domain environment), Windows will use instead NTLM for authentication between client and server
When encrypted Windows logon used in MRC and remote machine joined the domain, Kerberos works (it uses the negotiate package, which chooses Kerberos as a priority). It works with NTLM traffic disabled.
When Windows NT challenge/response authentication is used, MRC uses NTLM.
Dameware Remote Support & Mini Remote Control
  • Incorrect or restricted permissions on the remote machine.
  • The computer is not authorized in Active Directory.
  • GPO restriction
Do any of the following:
