Applications Systems
Assign a template to a node in SAM
This article describes how to assign a template or component monitor to a node.
11/29/2018 10:55 PM
9/15/2023 5:59 AM
This article provides step by step procedure on how to assign an application template to a node.
Server Application Monitor
N/A
  1. In your SAM Web Console, go to Settings > SAM settings > Application Monitor Template.
  2. Select the template in the left pane and then select the box next to application template.
  3. Select Assign to Node.
  4. Select Multiple Node.
  5. Click the Green arrow. The node moves to the center pane.
  6. Select all the preferred nodes.
  7. Click Next and continue with the rest of the steps.
  8. Assign the template to the node.
