Tools
Asset Sync Error: ORA-01882 timezone region not found
When you attempt to sync assets from an Oracle database, the following error is returned: ORA-00604: error occurred at recursive SQL level 1 ORA-01882: timezone region not found
For OSX or Linux Servers
- Open the
<webheldpesk>/conf/whd.conffile in a text editor. - Add the following to the
JAVA_OPTSsection. Place the entire set of arguments between the pair of quotes, in the following format:
JAVA_OPTS="-Doracle.jdbc.timezoneAsRegion=false" - Stop Web Help Desk.
- Start Web Help Desk.
For Windows Servers
- Open the
<WebHelpDesk>\bin\wrapper\conf\wrapper_template.conffile in a text editor. - Add the following JVM arguments to the
Java Additional Parameterssection:
wrapper.java.additional.xx=-Doracle.jdbc.timezoneAsRegion=false
wherexxis the next corresponding number in the list of arguments - Stop Web Help Desk using the Start Menu options (Right-click to Run as Admin).
- Start Web Help Desk using the Start Menu options (Right-click to Run as Admin).
