Applications Systems
Array and disk sensors are not polled from DELL and HP servers using the WMI polling method
This article explains why monitoring hardware health for Disk and Array on DELL or HP server using Agent or WMI polling doesn't work.
You must utilize SNMP polling to capture the disk and array hardware health information when polling HP or Dell server.
How to change polling from agent or WMI to SNMP
- Go to Edit Properties for the node.
- Select SNMP polling method.
- Enter community string information.
- Submit the changes to save.
Note: This is due to Dell and HP being limited to providing hardware health via WMI. See the SAM Admin Guide for more information.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
