Applications Systems
Appstack view in SAM displays incorrect server and application data
This article describes an issue that causes the Appstack view to display the incorrect servers and applications after upgrading to SAM 2019.4.
11/8/2018 2:24 PM
9/7/2021 5:09 PM
After you upgrade to SAM 2019.4, the Appstack view displays the incorrect servers and applications.
Server Application Monitor
After the upgrade, the Application Dependency Mapping (ADM) feature discovers new relationships and adds the relationships to the Orion Dependencies table. When AppStack retrieves the data from this table, it displays incorrect information in the Orion Web Console.
Submit a ticket to Technical Support.
