Apply device-based view limitations
The web console gives administrators the ability to apply device‑based view limitations.
- Example: You want to create a view with a resource to display last 25 Events on all UPS devices. In this case, we use type of limitation: Group of Groups: UPS.
To enable a view limitation:
- Click Settings in the top right of the web console.
- Click Manage Views in the Views group of the Orion Website Administration page.
- Select the view to which you want to add a limitation, and the click Edit.
- In the View Limitation area of the Customize View page, click Edit.
- Select the type of view limitation you want to apply, and then click Continue.
- Provide or check appropriate strings or options to define the device types to include or exclude from the selected view, and then click Submit.
Note: The asterisk (*) is a valid wildcard. Pattern limitations restrict views to devices for which the corresponding fields include the provided string.
