Tools
Applet stuck on restart in DRE
Steps for troubleshooting DRE when Applet is stuck on restart
- Everytime the PC is rebooted and applet session is prompted with the message "Waiting for a technician. Do not close this window"!
- Everytime the PC is rebooted a message saying "The applet has expired. Please contact the Support provider" pops up!
- The Applet service was likely not able to close correctly or a registry change is stuck pending.
- Attempt one of the following resolutions, any one of them should resolve the issue, however:
- Command line uninstall and manual registry delete:
- Check if the “BeAnywhere Support Express” service (internal name “BASupportExpressService”) exists;
- If it exists, please run the following command in an elevated cmd prompt: BASupAppSrvc.exe /uninstall;
- Search the registry for the string “BASupportExpress” which should appear inside Run or RunOnce and please remove it.
- It may happen that either the service or the registry keys don’t exist, but one of them is causing the issue.
- Launching a new session, suspending it and then closing it appropriately:
- Do an Applet Session to the computer that has the issue reported;
- Elevate privileges on the Applet Session;
- Don't close the Applet in the “X”, go to Session>Disconnect;
- After disconnecting wait for “reconnect” prompt and click Reconnect;
- Then wait for establishing connection and close the Applet the correct way by closing the window, clicking the X.
- Manual change of Startup app and folder removal:
- Go to Windows>Run, type "msconfig" and press enter.
- Open the Windows Task Manager, select the Startup tab and check if the Applet is there, if it is, disable it.
- Delete the folder for "C:\Users\USERNAME\AppData\Local\BeAnywhere Support Express\GetSupport" if present.
- Restart the computer.
