Applications Systems
Appinsight for Exchange appears as unknown
This article describes an issue where Appinsight for Exchange may appear as unknown in the web console
11/20/2018 10:30 PM
10/7/2019 2:12 PM
This article describes an issue where Appinsight for Exchange may appear as unknown in the Web Console.
Server Application Monitor
  • Full Language Mode was changed to Restricted Mode on the Exchange Server.
  • The following error is found in the logs where our script trys to execute:
    Script block literals are not allowed in restricted language mode or a Data section
  1. On the target machine, please navigate to:
    IISManager > Sites > default > Powershell > Application Settings, and Add/Change PSLanguageMode to FullLanguage
  2.  Run from the command prompt, IISRESET with administrator privileges
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
