Applications Systems
AppStack not drawing All Relationships
This article describes a one possible solution as to why the AppStack Environment does not highlight all VM's associated with each ESX Host which can be misleading when trying to map VM's to their Hosts / Data stores
11/11/2018 11:28 PM
6/27/2020 2:02 AM
The AppStack environment does not highlight all VMs associated with each ESX hosts which can be misleading when trying to map VMs to their hosts/data store.
Server Application Monitor
vCenter was deployed in a virtual machine which caused AppStack to treat is as a VM instead of vCenter. Thus, the  parent host/data center/vCenter is displayed instead of environment under the actual vCenter.
  1. Open the vSphere client and connect to your vCenter.
  2. Find the VM where the vCenter is installed.
  3. Go to the Permissions tab.
  4. Right click the credentials used for polling in VIM and select Properties.
  5. In the Change access rule option, select the No access value.
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
