Applications Systems
AppStack Environment for IBM FlashSystem Storage Array shows LUNs but no VMware Hosts, Datastores, or Virtual Center relationships in Storage Resource Monitor
This article discusses an issue where IBM FlashSystem LUNs appear in AppStack but VMware relationships such as Virtual Centers, Hosts, Datastores, and VMs are missing because the SRM topology job fails while processing hosts with multiple initiator ports.
This article discusses an issue where IBM FlashSystem LUNs appear in AppStack but VMware relationships such as Virtual Centers, Hosts, Datastores, and VMs.
In AppStack for the storage array, LUNs are visible but the VMware layers are empty.
No related Virtual Centers, Virtual Datacenters, Clusters, Hosts, Datastores, or VMs are shown for the affected storage array.
From SRM.Pollers.StorageArrayJob_XX_Topology:
2026-06-10 14:42:45,799 [STP SmartThreadPool Thread #8] ERROR SolarWinds.SRM.Pollers.Pollers.IbmFlashSystem.Jobs.IbmFlashSystemStorageArrayApiJob - System.InvalidOperationException: Sequence contains more than one matching element
at System.Linq.Enumerable.Single[TSource](IEnumerable`1 source, Func`2 predicate)
at SolarWinds.SRM.Pollers.Pollers.IbmFlashSystem.Jobs.IbmFlashSystemTopologyJobPoller.GetInitiatorEndpoints(String hostName, IEnumerable`1 hostPorts)
at SolarWinds.SRM.Pollers.Pollers.IbmFlashSystem.Jobs.IbmFlashSystemTopologyJobPoller.Execute(IIbmFlashSystemApiClient client)
at SolarWinds.SRM.Pollers.Pollers.IbmFlashSystem.Jobs.IbmFlashSystemStorageArrayApiJob.Execute(SRMStorageArrayJobDescription jobDescription)
SRM collects the array and LUN objects, but end-to-end mapping is not built because no SRM_LunMasking rows are written for the affected array.
The issue occurs because SRM assumes there will be only one entry for each host, but the API returns one entry for each port. If a host has two or more ports, the SRM poller will fail with an error and stops the job before it finishes mapping.
This issue is resolved in SolarWinds Self-Hosted Platform/SRM 2026.2.2 and later.
Upgrade to OSH/SRM version 2026.2.2 or later. After the upgrade, the IBM FlashSystem topology job processes hosts with multiple initiator ports, and VMware relationships (Virtual Centers, Hosts, Datastores, and VMs) are mapped to the storage array in AppStack.
