View title is not unique error found on Web Console
This article resolves the issue if you get the following error: View title is not unique in Web Console.
10/16/2018 4:53 PM
12/15/2021 8:18 PM
You get the following error on the Web Console:
View title is not unique.
Network Automation Manager
There is a view with the same name that already exists.
Rename the existing "Summary" view or views group.
  1. Navigate to Admin > Manage Views list.
  2. Rename the view from it's current title to something unique -> click Update button
  3. You should now be able to add tabs and resources to the view
