Applications Systems
AppInsight for SQL: Manage a specific database and its thresholds
This article describes how to manage a specific database and its thresholds using AppInsight for SQL.
- Log into the SolarWinds Web Console, and then go to the Summary Page.
- Click the AppInsight for SQL template > Database Details, or go to the Node Details page, and then click through the Application page until you get to the Database Details page.
- Click Unmanage to remove a database from monitoring.
- Click Edit Thresholds to change the thresholds for the components for a database.
- Verify that you are in the correct database.
- Click the + button to expand and change the threshold for a component.
- Click Override Instance for the threshold.
- Modify the threshold(s) according to your preference.
- Click SUBMIT to save and activate the changes.
