Applications Systems
AppInsight for SQL: How "SQL Job Agent Info" Monitor works
This article provides information on how AppInsight for SQL works.
11/29/2018 10:53 PM
6/25/2020 9:50 PM
This article provides information on how AppInsight for SQL monitors SQL Jobs
Server Application Monitor
  1. The Monitor runs the following script against the SQL Server being monitored:
SELECT
    j.name,
    j.job_id,
    a.last_executed_step_date,
    h.run_status,
    h.run_duration
FROM [msdb].[dbo].[sysjobs] j
LEFT JOIN [msdb].[dbo].[sysjobactivity] a on j.job_id=a.job_id
LEFT JOIN [msdb].[dbo].[sysjobhistory] h on a.job_history_id=h.instance_id
WHERE h.step_id=0
  1. Each Job's "Run_Status" column value is reviewed.
  2. The retrieved values are reported back by the Monitor.
The possible values are:
0 = Failed
1 = Succeeded
2 = Retry
3 = Canceled
4 = In progress
  • If a job was never run, then it has a status of Available (Up)
  • If a last run was successful, the status is calculated based on the duration threshold
  • If the last run has a status of Failed, the status is set to Critical
  • If the last run has a status of Retry or Cancelled, the status is set to Warning
Note: SAM does not poll information about the job scheduling state.
