Applications Systems
AppInsight for SQL: Auto Close option for database breaks polling of performance counters and database collation
The Auto Close option under Database Properties breaks the polling of performance counters and database collation.
11/11/2018 11:06 PM
6/29/2020 5:08 AM
Server Application Monitor
This is a known issue and SolarWinds recommends that you unmanage this database.
