Applications Systems
AppInsight for IIS is not polling
This article resolves the issue when AppInsight for IIS is not polling.
Re-register PowerShell:
- Open PowerShell via Run as Administrator.
- Execute the following command on the target computer:
Register-PSSessionConfiguration -Name Microsoft.PowerShell
For more information, see The WS-Management service cannot process the request.
Disclaimer: Please note, any content posted here is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
