Applications Systems
AppInsight for IIS error: PowerShell WebAdministration module test failed after changing from WMI to agent polling method in SAM
This article address an error in AppInsight for IIS after a server was changed from WMI to agent polling method
9/18/2019 10:01 AM
4/8/2025 9:15 PM
When monitoring AppInsight for IIS on a server that changed its polling method from WMI to agent software, you will come across the following error:
PowerShell WebAdministration module test failed.
Web Administration test failed: PowerShell WebAdministration module is not installed.
Alternatively, you may receive the following message:
WebAdministration module cannot be imported into the PowerShell session. System.ComponentModel.Win32Exception: Access is denied
Server Application Monitor
  • AppInsight for IIS was first configured to work on remote monitoring when the server was still on WMI polling method
  • Invalid credential assigned to the application
Disable AppInsight for IIS under List Resources
  1. Go to Manage Nodes
  2. Tick the affected server
  3. Click List Resources
  4. Uncheck AppInsight for IIS
  5. Hit Submit
Re-enable AppInsight for IIS
  1. Run another List Resources on the affected server
  2. Click 'Force Refresh' if prompted
  3. Check AppInsight for IIS
  4. Hit Submit
If receiving the Access is Denied message then you should
  • Attempt assigning a different credential to the application monitor
or
  • Change the credential to 'inherit from node' to use the local system account to poll the application data.
