Applications Systems
AppInsight for IIS: Quota Violation Error
This article resolves the Quota Violation error when monitoring AppInsight for IIS.
10/16/2018 9:20 PM
6/25/2020 9:29 PM
This article provides brief information and steps to resolve the Quota Violation error when monitoring AppInsight for IIS.
Server Application Monitor
The issue is caused when the quota limit is exceeded.
Change the quota limit. For example, if the you have 1,000 or more sites on IIS, the WMI provider will allocate more memory for polling then the raising of the memory quota limit.
To change the quota limit, refer to the following MSDN article: http://blogs.technet.com/b/askperf/archive/2008/09/16/memory-and-handle-quotas-in-the-wmi-provider-service.aspx (© 2015 Microsoft, available at https://blogs.technet.microsoft.com, obtained on June 27, 2015.)
Disclaimer: Please note, any content posted herein is provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software or documentation that you purchased from SolarWinds, and the information set forth herein may come from third parties. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment.  You elect to use third party content at your own risk, and you will be solely responsible for the incorporation of the same, if any.
