Applications Systems
AppInsight for Exchange error: Remote configuration failed
Remote Configuration Failed. Remote configuration was unsuccessful due to the following: "WinRM test was successful. PowerShell Exchange web site testing failed with the following error: Connecting to remote server failed with the following error message : The WinRM client received an HTTP bad request status (400), but the remote service did not include any other information about the cause of the failure. For more information, see the about_Remote_Troubleshooting Help topic."
The following error message appears when trying to configure AppInsight for Exchange:
Remote Configuration Failed Remote configuration was unsuccessful due to the following: "WinRM test was successful. PowerShell Exchange website testing failed with the following error: Connecting to remote server failed with the following error message: The WinRM client received an HTTP bad request status (400), but the remote service did not include any other information about the cause of the failure. For more information, see the about_Remote_Troubleshooting Help topic."
Note: The error on the component will still appear upon application of the resolution as the Server Mailboxes are polled once every day. The error should no longer appear the following day or during the next polling.
1. Create a wsMan listener by initializing $targetIP variable with the Exchange Server IP. Run the next query on the Exchange Server and give the output:
$targetIP = "192.168.3.52";
$hostname = $targetIP + "_Solarwinds_Exchange_Zero_Configuration";
$lifeTimeDays = 365 * 50;
try{
# Get the thumbprints of the SSL certificates that match the hostname
Write-Output "SSL certificates info:";
Get-Childitem -path cert:\LocalMachine\My | Where-Object {$_.Subject -eq "CN=$hostname"};
$thumbprints = Get-Childitem -path cert:\LocalMachine\My | Where-Object {$_.Subject -eq "CN=$hostname"} | Select-Object -Property Thumbprint;
# PowerShell magic to retrieve the first matching thumbprint (there'll probably only be one anyway)
$thumbprint = @($thumbprints)[0].Thumbprint;
Write-Output "Retrieved thumbprint:";
Write-Output $thumbprint;
# Create a WinRM listener, identifying the SSL certificate by the thumbprint
New-WSManInstance WinRM/Config/Listener -SelectorSet @{Address = "*"; Transport = "HTTPS"} -ValueSet @{Hostname = $hostname; CertificateThumbprint = $thumbprint};
} catch {
Write-Output "Unable to create wsMan listener. ERROR: $($Error[0])";
2. Recycle the following application tools:
- MSExchangePowerShellFrontEndAppPool (Default Web Site\PowerShell app.pool)
- MSExchangePowerShellAppPool (Exchange Back End\PowerShell app.pool)
- MSExchangeOWAAppPool (Default Web Site app.pool)
- DefaultAppPool (Exchange Back End app.pool)
Refer to Recycle an Application Pool on Demand (IIS 7) (© 2019 Microsoft, available at https://docs.microsoft.com, obtained on January 28, 2019) for more information regarding recycling application pools.
To test the Orion server's connection to the PowerShell website:
- RDP to the polling engine assigned to poll the node on that application.
Open a web browser and try to go to:
https://${IP}/powershell/
This website must resolve without error on the polling engine that is polling the exchange server for the Application to work.
This error is caused by the SolarWinds server not being able to hit the Powershell website. This can be caused by the exchange Powershell website's certificate being invalid or expired, incorrect port binding on the website, or firewall issues.
