Applications Systems
AppInsight for Exchange - WinRM unable to load assembly
Reference this article when WinRM unable to load assembly in AppInsight for Exchange.
The following steps should be performed on the Exchange server to remove the reference to the broken assembly:
- Run the following PowerShell Command:
# Scripts are not supported under any SolarWinds support program or service. # Scripts are provided AS IS without warranty of any kind. SolarWinds further # disclaims all warranties including, without limitation, any implied warranties # of merchantability or of fitness for a particular purpose. The risk arising # out of the use or performance of the scripts and documentation stays with you. # In no event shall SolarWinds or anyone else involved in the creation, # production, or delivery of the scripts be liable for any damages whatsoever # (including, without limitation, damages for loss of business profits, business # interruption, loss of business information, or other pecuniary loss) arising # out of the use of or inability to use the scripts or documentation. get-childitem -Path wsman:\localhost\plugin\microsoft.powershell\InitializationParameters
Working Server Output:
- Microsoft.WSMan.Management\WSMan: localhost\Plugin\microsoft.powershell\InitializationParameters
ParamName ParamValue
PSVersion 3.0
Non-Working Server Output:
- Microsoft.WSMan.Management\WSMan::localhost\Plugin\microsoft.powershell\InitializationParameters
PSVersion 3.0
assemblyname -
pssessionconfigurationtypename ShowSecurityDescr...
- The issue is with the "-" value so it must be removed.
- Run the following commands to remove the two extra InitializationParameters.
- Remove-Item -Path wsman:\localhost\plugin\microsoft.powershell\InitializationParameters\assemblyname
- Remove-Item -Path wsman:\localhost\plugin\microsoft.powershell\InitializationParameters\pssessionconfigurationtypename
- Restart the server.
