Applications Systems
AppInsight for Exchange: Generate the Zero Config script and manually run it on the target system
This article provides steps on manually generating Zero Config script, copy it to the target system and then run it. This usually happens when the Appinsight for Exchange Application's Configure Server button fails to copy the script to the target system.
10/15/2018 8:43 PM
9/29/2022 5:23 PM
This article describes how to manually generate the Zero Config script, copy it to the target system and then run it. This usually happens when the AppInsight for Exchange Application's Configure Server button fails to copy the script to the target system.
Server Application Monitor
  1. Open a command prompt on the system hosting SAM.
  2. Go to the SAM installation directory.  By default, the location is C:\Program Files (x86)\SolarWinds\Orion\APM\.
  3. Run the following command:
    SolarWinds.APM.RemoteWinRmConfiguratorFull.exe AQEBAQ== AQEBAQ== AQEBAQ== AQEBAQ== AQEBAQ== AQEBAQ==
  4. Go to C:\ProgramData\SolarWinds\APM\RunWinRMConfigurator\ and open the WinRMandWindowsAuthenitcationEnabler.ps1 using a text file editor such as Notepad.
  5. Initialize the following variables with values:
    • $userToFind: Set the value for this to the username of the account to be used for monitoring.
    • $userDomain: Set the value for this to the domain of the account specified for $userToFind.
    • $targetIP: This value is the IP address being used by the Node the ApInsight for Exchange Application is assigned to.
  6. Copy the script file to the Exchange Server in question and run it in an elevated PowerShell prompt.
