Unable to Add, Edit or List Resource for nodes assigned to an Additional Polling Engine with error (SolarWinds.ApiProxyFactory.TransientApiProxyException)
This article shows how to resolve an issue wherein all Nodes polled by an Additional Polling Engine cannot Add, Edit or List Resources.
When adding, editing or Listing Resources for all Nodes polled by an Additional Polling Engine, the following issue is presented "SolarWinds.ApiProxyFactory.TransientApiProxyException"
- WARN and ERROR seen in the OrionWeb.log from the Main Polling Engine (C:\ProgramData\SolarWinds\Logs\Orion):
WARN SolarWinds.Orion.Core.SharedCredentials.OrionEntitySharedCredentialManager`1 - (null) Found no CredentialRelations records for entity Uri swis://<ServerName>/Orion/Orion.Nodes/NodeID=531 and use PaloAltoFirewall ERROR ApiProxy<ICoreBusinessLayer, ServiceDirectoryQueryInternal> - (null) All #3 retries calling an API channel from a pool 'RootPool' failed due to a transient error detected. SolarWinds.ApiProxyFactory.TransientApiProxyException: Exception of type 'SolarWinds.ApiProxyFactory.TransientApiProxyException' was thrown. ---> System.ServiceModel.EndpointNotFoundException: No DNS entries exist for host APE_Hostname. ---> System.Net.Sockets.SocketException: No such host is known
or
ERROR ApiProxy<ICoreBusinessLayer, ServiceDirectoryQueryInternal> - (null) All #3 retries calling an API channel from a pool 'RootPool' failed due to a transient error detected. SolarWinds.ApiProxyFactory.TransientApiProxyException: Exception of type 'SolarWinds.ApiProxyFactory.TransientApiProxyException' was thrown. ---> System.ServiceModel.EndpointNotFoundException: Could not connect to net.tcp://inkeosolar0001.ad001.siemens.net:17777/orion/core/businesslayer. The connection attempt lasted for a time span of 00:00:01.0313300. TCP error code 10061: No connection could be made because the target machine actively refused it 19.1.1.1:17777. ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 19.1.1.1:17777 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Connect(EndPoint remoteEP) at System.ServiceModel.Channels.SocketConnectionInitiator.Connect(Uri uri, TimeSpan timeout) --- End of inner exception stack trace ---
- The hosts file on the Main Polling Engine (C:\Windows\System32\drivers\etc) has an incorrect IP Address or missing information.
- Port 17777 is not open bidirectional between the Main Poller and Additional Poller.
Solution 1
Update the hosts file of the Main Polling Engine and Additional Poller according to its necessity (C:\Windows\System32\drivers\etc).
Solution 2
Test port 17777 from both Main Poller and Additional Poller to make sure they are open bidirectional according to the article SolarWinds Port Requirements - Additional polling engine
- Open PowerShell with administrator privileges and enter the following command, replacing '<IP_ADDRESS>' with the IP address from the Main or Additional Poller.
tnc <IP_ADDRESSS> - Port 17777
