Alerts triggering for deleted nodes
This article explains how to stop alerts or events from triggering for deleted nodes. This occurs when the object is turned off before it is removed from your SolarWinds product.
- Resolution #1:
- Log on as an administrator to the server hosting your SolarWinds Orion installation.
- Navigate to Start > Programs > SolarWinds Orion > Advanced Features > Orion Service Manager.
- Select SolarWinds Alerting Service V2.
- Click Restart.
- Resolution #2:
- Login to Orion Web Console
- Browse Alerts > Manage Alerts
- Search for the alert being trigerred
- Disable the alert.
- Reenable the alert and monitor.
Note: To prevent this issue, unmanage the object on the Web Console before decommissioning it.
