Alerts for volume utilization are not triggered when they appear to have reached their threshold value
In some cases, the Volume Utilization value that NPM displays in the Orion Web Console appears to be at the threshold for an alert, and yet the alert is not triggered.
11/7/2018 5:27 PM
11/7/2018 5:27 PM
Network Performance Monitor
This happens because NPM rounds the volume utilization value up or down to display whole numbers in the Orion Web Console. For example, if the volume utilization value is 59.85%, it is displayed as 60% in the Volume Details page of the Orion Web Console. A volume utilization alert with a threshold of 60 is not triggered because the actual value is less than 60.
This behavior is by design. However, to avoid the appearance of alerts failing to be triggered, you can adjust the threshold value  to less than .5% of your target trigger value. For example, change the trigger condition to Volume Percent Available is greater than or equal to 59.5%.
