Applications Systems
Agent constantly loses connection
This article provides brief information and steps to resolve the issue when the Agent constantly loses connection. Server and Application Monitor (SAM).
11/29/2018 10:52 PM
3/23/2022 1:27 PM
The following error appears in the Agent Business Layer log:
ERROR SolarWinds.Orion.Core.Common.CoreErrorHandler - Error occurred on Business Layer call. Type: System.ServiceModel.CommunicationException
Message: 'The socket connection was aborted. This could be caused by an error processing your message or a receive timeout being exceeded by the remote host, or an underlying network resource issue.
Server Application Monitor
The following steps is a workaround:
The agent needs to be configured to use local host as the hostname. To do this:
  1. Go to C:\Program Files (x86)\SolarWinds\Agent.
  2. Open SolarWinds.Agent.Service.exe.cfg.
  3. In the <target> section, search for <host0>(server name)</host0>.
  4. Change (server name) to localhost.</target>
Note: This only applies to the agent running on the actual polling engine.
