Applications Systems
After upgrade to 2024.4, retention settings for AppInsight for SQL were reset to default values
AppInsight for SQL data retention is reset to defaults after an upgrade.
This article describes the workaround for Appinsight for SQL retention settings which were reset to default after upgrade.
This is a know issue in SAM 2024.4.
This issue is addressed in SAM 2025.2. Consider upgrading your environment. If you can't upgrade, please use the workaround below.
Set the retention settings one more time in All Settings → SAM Settings → Data & Database Settings
